Front Brake Problem - Sticky
My front brake is sticky, and in an emergency situation, could cause me to either apply too much brake or not enough. I made a video of the problem. Sorry for the poor quality, as it was made with my phone. Bad master cylinder? Brakes need bled? Just needs lubricated or something? Any help will be appreciated.
http://s143.photobucket.com/albums/r...=VID_00012.flv
Edit - Just tested the video link and you may have to open it a second time to get the video to play.....
The best thing you can do is to bleed the brake fluid, then remove your brake calipers, remove the brake pads and disasembly the calipers and clean the internal pistons and all the parts from inside, just pay attention so you wont forget how to put them back together, you will be surprise how much dirt will come out from them that is causing you problems, I recomend an sprayable brake and parts cleaner and also a small brush to get the job done. You will be happy with the results and more than confidentnow that you know that you check your brake system. Good luck.
