Front brake? Engages "late"
Old 04-23-2013, 08:41 PM
Gnarly 928's Avatar
Default Front brake? Engages "late"
Hello all,
2003 F4i with almost new pads. I have adjusted the lever in and out to suit my hand size, so I am familiar with that lever adjustment. I recently swapped to some new Galfer SS dual lines and bled everything correctly. I now have much nicer feel at the lever and the bike is better to ride but I have always, since I got this bike, found the lever has to be moved much too far(compared to all my previous bikes) before I encounter any braking force...
At present, I have the lever adjusted so that I can get two finger front lockup without crushing my other fingers on the throttle....just... When I adjust the lever farther away from the bar ( to an uncomfortable distance that makes it difficult to keep my fingers on the lever during fast technical riding), I still seem to need the same amount of lever movement until the pucks engage the rotor... No matter where I adjust the brake lever, it seem like I have to squeeze it almost half it's travel before I get any braking. Is that normal? I'd rather see less 'slop' in the system...have the brake begin to engage with just a little freeplay, not almost half the lever travel. I know I have a good bleed. The brakes are quite firm, not at all squishy...they just don't start working till the lever comes halfway to the bar...every time...no pumping up makes a bit of difference....I know what good brakes feel like and these are good, they just start with a lot of lever travel first.
Is there a way to adjust that or revise a piece to improve the action so that I can get quicker braking without moving the lever a couple of inches each time I want to slow up? I recently replaced the whole mechanism of the brake lever with an OEM Honda one, so it's not a cheap lever from China...The hydraulics seem fine everywhere, the discs look fine and are within spec. Help!
Don Hanson
Old 04-23-2013, 09:28 PM
74demon's Avatar
Mine acted similar. Had to pull it half way before it did anything, sometimes crushing my fingers. It felt s little better after a bunch of stops, but not much.
I solved it by bleeding the system over and over. I'd bleed all the air out and it would feel better for awhile, then go back after sitting a week or so. Finally after months of this, I was able to get that stubborn air bubble out. Been good ever since.
Old 04-23-2013, 11:32 PM
Gnarly 928's Avatar
Well, I go at the bleeders again then. Thanks....This is my first CBR and I thought it might be something like the R.R problem or the CCT problem... "a CBR thing" Stubborn air in the system, I can deal with that now that I know it isn't something 'engineered in'....
Don Hanson
Old 04-23-2013, 11:40 PM
74demon's Avatar
Make sure your banjo bolt on the master it tight too. If the crush washers are sealing good, you will never get the air out.
mrsmobbins101
04-01-2013 11:07 AM
fyv0h
12-11-2011 05:04 PM
jun167
09-03-2009 06:06 PM
KenG
CBR1000F For Sale / Found
08-09-2009 05:20 AM
Quick Reply: Front brake? Engages "late"
