Flush mounts not blinking!
Old Apr 25, 2012 | 07:16 PM
WangDangger's Avatar
Unhappy Flush mounts not blinking!
I got a 2008 CBR600rr and I installed LED flush mounted turn signals, they light up fine (running lights) but when i press the signal left or right it doesnt blink it looks like the bulb goes out, but when i turn the signal back off the running light comes back on. So I bought a LED flasher relay and all the did was make by tail light blinkers back to original flash rate! any ideas would be helpful!
Old Apr 25, 2012 | 07:35 PM
Turbulenz's Avatar
Official Welcome Crew
Did you install the diodes so you can run all 3 wires or did you simply tie both power leads together?
Old Apr 25, 2012 | 07:40 PM
i was reading up on some other post about those diodes i didnt know about those yea i just tied the wires together!
Old Apr 25, 2012 | 07:45 PM
jeffjones's Avatar
That is your problem right there.
You have 2 choices
1) Do the diodes and have running/turn signals.
2) Connect just the turn signal wire and tape off the running light wire and have them always off and blink when you turn.
Turbulenz's Avatar
The diodes cost you a few bucks at radio shack.. Will solve the problem. Check the sticky in the how to section
Old Apr 25, 2012 | 07:49 PM
Turbulenz's Avatar
Or what jeffjones said lol
Old Apr 26, 2012 | 08:39 PM
ok so i got the diodes, installed them now i have running lights and blinkers but now the blinker indicators on my guage cluster stay constantly lit and so do my back blinkers, it didnt do that before?
Old Apr 26, 2012 | 09:10 PM
ahh ha i figured it out they were staying constantly lit cus where the two wires tie into the diodes then u twist the other end of the diodes together to then feed out to one wire, well i forgot to seporate the two wires when taping them up (oppisite side of the one wire lead out) so they were touching so i simply taped the two wires and diodes seporately so they wouldnt touch and WALA problem solved!!!!!!!!!
Old Apr 27, 2012 | 02:01 AM
fordmanforever's Avatar
Great info guys thanks for the help as I am trying to sort out the signals myself.
ghost'n_ppl
Jul 13, 2009 03:25 PM
Lego
Jun 28, 2008 07:51 PM
lance_buma
Jun 22, 2007 12:23 AM
thetooth
Feb 17, 2006 12:51 AM
