Throttle Not Returning To Idle On Its Own
Old Apr 25, 2012 | 08:54 PM
justasquid's Avatar
Loosen the clamp that your throttle attaches too. Sometimes, the rubber from the throttle grip will get pushed into the housing and create drag. Loose it up and pull it away from the grip, then retighten. Thats the first thing I would check anyway.
Beyond that, it could be a weak throttle return spring on your rack.
Old Apr 25, 2012 | 09:19 PM
That Guy in Maine's Avatar
I know mine stuck and didn't move at all when the clip on was bent, any way it could have been slightly bent so that it sticks with less pressure on it?
If not that, try lubricating the plastic throttle tube that is on the clip on itself.
and justasquid also has a good idea.
Good luck!
Old Apr 26, 2012 | 02:20 AM
CJardine's Avatar
Track junkie & modaholic
I would first make sure my throttle cables were routed correctly I know that on my bike if they are even twisted once, my throttle wont budge by itself.
Old Apr 26, 2012 | 01:14 PM
gotcbr's Avatar
Originally Posted by justasquid
... Sometimes, the rubber from the throttle grip will get pushed into the housing and create drag. Loose it up and pull it away from the grip, then retighten. Thats the first thing I would check anyway...
That's the first thing I do when I get my bike off the trailer at the track. ;-) I use the old model canyon-dancers. They're great for strapping & securing the bikes to the trailer but the throttle side grip can easily wedge up against the housing if it has the opportunity. A slight adjustment usually corrects it. The new style canyon-dancer eliminates this w/a hard rubber cup that mounts over the end of the clip-on/grip. Canyon Dancer Inc.
C-Kan
Sep 28, 2012 06:47 PM
Hurricane619
Jun 3, 2011 08:36 PM
MetaLord 9
Aug 24, 2009 06:52 PM
gruntworker
Jul 29, 2009 07:50 PM
ampfp
Jun 18, 2008 01:59 PM
