non-returning throttle
Old Jun 17, 2008 | 12:35 PM
ampfp's Avatar
Default non-returning throttle
If my throttle returns very slowly, which cable could be jammed? top or bottom? (see pic!)
I'd think either of them could cause the issue...? which one should I replace
[IMG]local://upfiles/11015/188E0139AD894059800735736DE5413A.jpg[/IMG]
Old Jun 17, 2008 | 12:44 PM
honda502's Avatar
Default RE: non-returning throttle
It could be either one. It could also be the actual throttle tube. You need to disconnect them one at a time and check the cables, then disconnect both to check the trottle tube.
Old Jun 17, 2008 | 03:38 PM
krash's Avatar
could also be that your grip has slipped down a little and is rubbing on the bar end. mine does that alot, especially after using a canyon dancer.
what ever it is, fix it before you ride again.
Old Jun 17, 2008 | 03:49 PM
buckd44's Avatar
yes check the grip first..
Old Jun 17, 2008 | 03:55 PM
WOT's Avatar
WOT
As stated above, it could be just about anything. I would slowly start taking things apart and keep checking as you loosen each item a little and it should reveal the issue.
Old Jun 17, 2008 | 06:03 PM
MC_spirited's Avatar
Also look into cable lubers. They work alright and keep your cables clean and smooth.
Old Jun 18, 2008 | 01:59 PM
Firefly's Avatar
After seeing the pic u posted...Im gonna give it a wild guess and say its probably the lower cable. check for kinks and see if the cable is getting hung up anywhere along the line. As was mentioned earlier, Definitely get some cable lube.
Czechmate
Oct 1, 2014 10:44 PM
04F4I0321
Dec 14, 2013 11:07 AM
Endless
Jul 6, 2012 03:25 AM
Jamc9103
Apr 27, 2012 02:54 AM
segraves1
Jun 5, 2011 10:35 AM
