Flasher relay wire help!!
so the guy i bought my 95 900RR from cut the turn signal flasher relay totally out. there are three wires. can i put prong attachments on each wire and then hook it straight to the prongs on a three prong flasher?? Any ideas besides buying a new harness or finding a used one to cut that connector off?? i would think this would work but im not an electrical guy im more mechanical. shouldnt be any difference from what im thinking. just want some opinions yall... ohh and my signal are all flush mounts but not LED
yeah i believe you should be able to connect those wires right to the new flashers, you may need to put the resisters that usually come with after market flashers in line to make em blink tho unless they are built right in to the flashers. if you cant get em to blink and they just stay lit then prob have to get a new flasher relay and hook that back in.
muckdawg24
09-17-2007 12:13 PM
