Flasher relay
Old May 10, 2007 | 08:32 AM
bornluckee13's Avatar
Default Flasher relay
Ok, so I searched some threads and All I could find were vauge replies of "Its built into the dash" and " I just replaced mine, It's plug and play" I was wondering if anybody out their would be kind enough to tell me where the flasher relay on an 05 600rr is? The crazy fast blink will give me a seizure for sure! Thanks fellas.
Old May 10, 2007 | 03:43 PM
elbaguy's Avatar
Default RE: Flasher relay
On my '05 F4i its behind the headlight assembly. You have to remove the upper fairing to get to it. I ordered a universal flasher relay to put but so far I haven't had the guts to take the front of my bike apart. I'm trying to slow down the flash rate for my integrated tail light.
Old May 15, 2007 | 05:35 PM
2006f4ido's Avatar
http://www.600rr.net/vb/showthread.p...+flasher+relay
I did the 2nd one down...worked like a charm got the relay looked at the picture.....matched the wires.......spliced into them took 15 minutes and works great and....DID NOT have to remove front section only left side (where other relays are)....
Old May 26, 2007 | 05:46 AM
crunkchris's Avatar
just get a resistor from radio shack to slow it down
Old May 26, 2007 | 09:04 AM
sfd540's Avatar
i got mine on ebay the same one for my 00 f4 and my 07 600rr no cutting or anything just unplug the relay plug this one in and they flash normal again. both time the relay is under the seat next to the fuses and battery. dont know about the 05 but this worked on my 00 and 07.
vfrman
Jul 7, 2010 02:56 PM
muckdawg24
Sep 17, 2007 12:13 PM
sic00F4i
Feb 10, 2007 04:00 AM
elbaguy
Dec 20, 2006 04:24 AM
