Flasher relay help...
Old Feb 10, 2007 | 03:32 AM
sic00F4i's Avatar
Default Flasher relay help...
Any ideas where the flasher relay would be on my 06 F4i? I've installed new flush mounts and a intergrated tail. I have a relay coming for the blinker speed but can't seem to locate the factory relay. No help in the owners manual. Just want to get ahead of the game and remove what I need to do a quick install. Thanks for you time!
-J
Old Feb 10, 2007 | 03:42 AM
Pugetpower's Avatar
Default RE: Flasher relay help...
If the 06 is like the 02, take off the upper cowl (like you're changeing headlight bulbs) it will be between the two headlight housings.
You will see 2 things attached to connectors....the blinker relay is the one on the right (if you looking at it from the seat).
Old Feb 10, 2007 | 04:00 AM
sic00F4i's Avatar
Got it pugetpower, thanks. You are correct on the location.
vfrman
Jul 7, 2010 02:56 PM
Jerzdan
Jul 15, 2009 09:38 PM
muckdawg24
Sep 17, 2007 12:13 PM
elbaguy
Dec 20, 2006 04:24 AM
