faulty ss lines?
Old May 10, 2007 | 05:16 PM
Err's Avatar
Err
Default faulty ss lines?
anyone ever hear of someone having faulty ss lines?
Old May 10, 2007 | 06:29 PM
therabbit's Avatar
Default RE: faulty ss lines?
I've heard of crap quality SS lines from ebay and whatnot. What do you mean by faulty though? Did it blow out?
Old May 10, 2007 | 06:38 PM
Err's Avatar
Err
no. but for the life of me i can't get them to bleed. i've done absolutely everything i could think of. i've swapped every braking component in the system, the only part that i have yet to switch out is my russel ss lines. so i'm going to switch them out with some galfer lines and see what happens.
anyone ever have bad luck with russel lines?
Old May 10, 2007 | 06:39 PM
therabbit's Avatar
Please take no offense, but are you bleeding them correctly? Have you bled brake lines before?
Old May 11, 2007 | 10:44 AM
jbreit's Avatar
I've had OEM lines start to leak....never aftermarkets. I've had Goodridge and Russell lines with no issues.
Getting new lines to bleed takes time and patience. I have a vacuum bleeder which really helps fill the system fast without the messybleeding of the master cyclinder.Even then it can still take quite a few rounds of going from side to side. After they are filled up, hand pumping seems to carry the air out better.
Old May 13, 2007 | 10:56 PM
Err's Avatar
Err
ORIGINAL: therabbit
yes
Old May 13, 2007 | 11:25 PM
Triax's Avatar
Is any fluid at all coming out? are the banjo bolts allowing fluid to pass at all?
Old May 13, 2007 | 11:30 PM
Err's Avatar
Err
ORIGINAL: Triax
yes
Old May 14, 2007 | 01:39 PM
Tahoe SC's Avatar
dude...you AGAIN?
muhhahahah...
i guess it's not all fixed! bring your bike to me, we'll sort this BS out.
if SS line is bad, it will leak...most likely at the banjo fittings. otherwise, the problem lies elsewhere...like the MC...or a stubborn bubble at the banjo and MC.
tap the shiznit out of the lines as you are bleeding.
b0wla
May 4, 2013 04:05 PM
William Haze
Oct 29, 2012 08:32 PM
cbrosu
Aug 25, 2012 02:25 PM
subyman1440
F2 Tech
Mar 24, 2012 12:10 AM
dvslaz
Jul 25, 2011 01:49 AM
