fast blinkers
I just put on a turn signal eliminator for the rears and have noticed that when the brake is on a short occurs and the blinkers blink rapidly. I assume this is normal, but is there any way to get rid of that and make them blink normal when the brake is on? I have stock tailights and front blinkers (no LED). Its an F3 too.
What exactly did you install again? If its a clear alternatives this behavior doesn't seem right, even with the need for transistors. I'm wondering if you wired it right. You might have wired your turn signal wires (yellow on a Clear Alternatives) to your brake wires on the bike. (???)
my first f4i was like that installed the integrator i got off ebay on it and when the brake switch kicked in they blinked fast. It quit as soon as you let off the brake. Lot of people i know have had this happen its normal. Probably a simple fix to it but it doesnt bother me
