Fan shorting? Short of some sort maybe?
Old May 10, 2014 | 09:11 PM
Canadian_Wanabi's Avatar
New Member
Default Fan shorting? Short of some sort maybe?
So far I've replaced, Stator - Battery - Regulator/Rectifier(3x)
I've Been testing the voltage Before/After I ride.
Results are that around mid 13.7 +/- before i leave. Then around 11.9 +/- at 4-6k;
All stator Coils look mint still
Any ideads?
Have noticed that my fan has been sounding really funny, And Thought i smelt Burning Rubber from around that area one day. IF there was a short with the Fan, Could that be were I'm getting my leakage at?
Old May 11, 2014 | 02:10 AM
Jukkis's Avatar
Unplug the fan while engine is running and see if voltage rises to normal.
Have you checked the stator? Should be 0,1...1,0 ohms between all 3 wires and no ground leaks.
Check the main 30A fuse for bad connection/melting. And other connectors also.
Old May 11, 2014 | 11:51 AM
CorruptFile's Avatar
June 2013 ROTM
Check your spark plug leads. I had one get worn through by the fan blades.
T-Rich
May 4, 2012 12:48 PM
kotared
Aug 20, 2008 12:08 AM
Toolwalz
Dec 12, 2007 06:07 PM
txmorgan
Aug 19, 2007 07:46 PM
cbr_newbie
Jul 21, 2007 11:30 PM
