F4i will not start
yes i got a 06 f4i that has been sitting for over a year with the switch in the Fi light stays on. it spins over but to start. im a mechanic so. i took of the tank i have fire to the plug if i spray carb cleaner in the intake it will fire off. but the fuel pump is not running and i have no injector pulse all fuses are good unless there is more than what u can see with the seat off. i have jumped the bank angle switch and still nothin. can anyone please help
If the fuel pump is not priming. Then its a pump issue.
Pull the codes first. Then I would run direct power to it and see if that works.
If it does its wiring
if it doesn't it the pump.
Also take a volt meter to the connections to see if that's fine also.
i put a new pump in still nothing there is no injector pulse either i jumped the relay for the fuel pump and it still want start i was wondering does the pump power run through the computer or no
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
JayBoCC2
Jun 23, 2009 10:23 PM
