F4i - Swing arm Sliders - is it possible???
RE: F4i - Swing arm Sliders - is it possible???
Honestly it would depend on HOW you attached the slider to the swingarm if it would be strong enough. You would NOT want to just drill a hole and tap threads into the aluminum because you will most likely have some sort of steel bolt included with the slider. If you put a steel bolt into an aluminum swingarm the bolt could just rip the threads out of the swingarm if it was subjected to much force since the aluminum is softer than the steel. An additional mounting plate would be the better way to go if it was welded or PROPERLY rivited to the swingarm.
Yes it is very possible & EASY, I did it in about an hour.
check this out http://forums.cbrworld.net/forums/140623/ShowPost.aspx
ORIGINAL: BlkF4I
[IMG]local://upfiles/1690/B91B7451C96F4762B679DE50F920609D.jpg[/IMG]
