F4i leaking oil
Old Sep 21, 2017 | 12:11 PM
rxEST's Avatar
Default F4i leaking oil
Hello
i have a problem with an oil leak. Leak is ​​​coming from the top of the gearbox i assume.
Couple of days ago i removed the gas tank but its so tight that i didnt see any obvious spot for leaks.
There is a sensor of some sort that looks suspicious.
What sensor is that and is there any possibility that oil leaks from there?
2002 F4i
Help me please
Old Sep 21, 2017 | 12:43 PM
74demon's Avatar
That's your speed sensor and it does have an o-ring seal. It goes into the crankcase, so it's possible that it could leak. However it shouldn't leak much as it's on top and not submerged in oil.
Old Sep 22, 2017 | 01:35 PM
rxEST's Avatar
Thanks for the reply.
The problem was that there was no o ring under the speed sensor. Added a new seal and problem fixed.
Thanks
Old Sep 22, 2017 | 01:48 PM
Gunk's Avatar
Which asks the question, why did someone remove the speed sensor?
Old Sep 22, 2017 | 01:58 PM
rxEST's Avatar
Maybe someone replaced the sensor and had too much vodka?
CBRcheez
Nov 11, 2008 01:27 PM
liljoec
Jul 14, 2006 12:35 AM
907hondaf3
Mar 24, 2006 02:32 AM
mini bagels
Mar 6, 2006 04:06 AM
FSUJames
Nov 14, 2005 07:26 AM
