F4i with 2k miles bogging and running like crap?!
ok, so last night i went over some **** that i can check off the list and also got a little closer to the problem. I let the bike run for a minute and sprayed brake clean on the headers and its showing that cylinder two isnt heating up as the other ones do as it does not burn/evaperate the brake clean.
-Pulled off the the injectors and switched them around and fired the bike up again.. still cylinder is still cold and definately is getting gas.
-Next, went back to the spark plugs and tested for spark and sure enough it had spark
So im getting gas and im getting spark. The bike still shoots out a little white smoke and smells like gas.
Any suggestions?
Any suggestions?
it really doesnt sound all that different when idleing.. it just lacks power, like a delay in throttle response.. when i rev it kinda acts like its runnin on 3 and then in higher rpms seems fine...
What about unplugging cyl #2 injector? You replaced it with another with no change which proves the injector is good but doesn't prove the wiring or signal to pulse. Try that and see what happens.
