F4 Engine trouble, odd compression
Old Apr 14, 2012 | 01:48 PM
anonu's Avatar
Registered Users
Default F4 Engine trouble, odd compression
In the fall my 2000 CBR F4 was running badly, smoke out the back, rough, then died. Layed it up for winter and now I'm getting to work on it again.
Step 1, check compression:
Cyl 4: 100 PSIg
Cyl 3: 0 PSIg (completely nothing).
Cyl 2: 130 PSIg
Cyl 1: 60 PSIg
Keep in mid that this is with a stone cold engine from the winter, it's about 15°C for the test.
I will do a leak down test next, but what in the world is causing 0 PSIg?
The bike has about 35000km (22000mi), no other noises (ie metal bike flying around in the cylinder) that I can hear. engine turns over fine.
Old Apr 14, 2012 | 08:20 PM
Dirtrider009's Avatar
Bad rings, cracked piston, stuck valve, numerous things can cause low/no compression. u said it was smoking badly before it died, so i would think rings or cracked piston allowing oil back into the combustion chamber causing it to spit smoke.
CJardine
May 5, 2013 01:24 PM
atxf4i
Jul 27, 2009 08:49 PM
tmihaylov
Dec 23, 2007 01:42 PM
corteztk1982
Sep 4, 2007 12:42 AM
Triangle
Jan 17, 2007 03:15 PM
