Engine Compression
Old May 4, 2013 | 04:30 PM
CJardine's Avatar
Track junkie & modaholic
Default Engine Compression
Either I suck at using google (entirely plausible) or it just cant be explained in plain English. If I increase my compression ratio, at what point do i need to consider raising the octane rating of my fuel, and how do I figure out what octane is right.
Second, I haven't done to much reading on this but can I use F4i pistons in an F4 engine? Thanks for any replies.
Old May 5, 2013 | 09:54 AM
MadHattr059's Avatar
Getting a definitive answer is going to be tricky.
Here's some of what I found googling "octane rating vs compression ratio"
and "Octane vs Compression Ratio Chart"
Octane rating - Wikipedia, the free encyclopedia
Compression versus Octane chart?
Gasoline FAQ - Part 3 of 4Section - 7. What parameters determine octane requirement?
Daytona Sensors LLC - Tech FAQ Engine Tuning
Classic Inlines - Compression Ratio's
Tip for googling, check the bottom of the search result page for suggestions
on search queries based on other peoples similar searches.
Hope this helps, Ern
Old May 5, 2013 | 01:18 PM
CJardine's Avatar
Hmm those have pretty much all the same info as I was able to find. The reason for my asking is if my compression ratio gets bumped up from 12.0:1 to 12.8:1 or even 13.5:1 what octane will I need to use? Looking at building a second engine for my F4 and want to learn as much as I can before the $$ starts to leave my pockets.
Old May 5, 2013 | 01:24 PM
Conrice's Avatar
13.5 will require premium
anonu
Apr 14, 2012 08:20 PM
atxf4i
Jul 27, 2009 08:49 PM
tmihaylov
Dec 23, 2007 01:42 PM
corteztk1982
Sep 4, 2007 12:42 AM
Triangle
Jan 17, 2007 03:15 PM
