f3 wont start? relay just clicks?
Old 10-12-2008, 06:23 PM
hedtrip's Avatar
Default f3 wont start? relay just clicks?
ok my 96 f3 wont start unless i push start it.
& when i try to turn it over the starter relay clicks repeatedly nothing else.
i've replaced the starter, regulator, starter relay & battery.
Old 10-12-2008, 07:21 PM
hedtrip's Avatar
Default RE: f3 wont start? relay just clicks?
wheres the kill switch on these ? & how do bypass it?
Old 10-12-2008, 08:09 PM
pacemaker's Avatar
Kill switch is on the right handle bar, but even when on you should not get the 'click'. Just the lights on. Even though you replaced the battery, did you fully charge it?. Check the connections the starter again, check your fuses.
Old 10-12-2008, 08:37 PM
its also very possible that your battery cable, or one of the wires somewhere is corroded and damaged as a result, preventing the starter from recieving the proper voltage, which could be your problem.
Old 10-13-2008, 08:49 PM
hedtrip's Avatar
i found the problem ... [:@] alot worse then expeted.
Old 10-14-2008, 09:04 AM
marc0011's Avatar
OH SHYT!! That is not good at all man []
Old 09-07-2022, 11:51 PM
Deepsixed9's Avatar
I'm a new to motorcycles and am thinking about buying a 94 CBR 600 and I think that's what wrong with it. What priec of the bike is that called and how do I fix it
Old 09-08-2022, 11:19 AM
@Deepsixed9 Hi and welcome to the forum. If your engine looks like this section of the starter drive, then you don't fix it. You get another engine. Ebay is going to be your friend on this one.
Old 09-08-2022, 11:33 AM
dannoxyz's Avatar
This is what can happen when you have hydrolocked engine. Caused by leaky petcock and carbs, which drips petrol into engine when sitting. Then when starter tries to spin engine, it can't compress cylinders filled with petrol. That mounting-point for starter-clutch takes brunt of force trying to spin engine and cracks. In luckier cases, it strips teeth off ring-gear, which can be repaired. But not engine-block.
maflel
03-05-2020 12:07 PM
rustyrobot
11-07-2011 06:30 PM
96@cbr
08-25-2011 11:02 PM
andmorse
06-09-2011 12:38 PM
daxbat
03-12-2006 04:15 PM
Quick Reply: f3 wont start? relay just clicks?
