F3 weird problem
Old Oct 24, 2007 | 01:18 PM
HondaCbr600F3's Avatar
Default F3 weird problem
Ok so I think this maybe the cct but I dont know. Here is some of the problems after like 7 grand the bikes makes alot of noise and really does not want to pull vary hard. It almost feels like something is draging on the bike but when I pull the cluth in the hole bikes rolls good no rubs or anything. The bike has 25K on it and really when its not under load the bike free revs with know more noise then the dayI got it just under load its gets really winy. The only thing i can really think of is timing with the cct any in put would be nice. thanks guys.
Old Oct 24, 2007 | 02:24 PM
marc0011's Avatar
Default RE: F3 weird problem
It doesn't sound likea CCT.Whena CCT is going bad, there is a noise that sounds like a marble bouncing around in the valves at idle or lower rpms when the engine is cold. Once the engine warms up, there isn't too much noise.Maybe the timing of the bike is off?
Old Oct 24, 2007 | 02:36 PM
Scrufdog's Avatar
have ya tried some carb cleaner in the tank?
Old Oct 24, 2007 | 04:55 PM
The sprocket and chain are new and in good shape. Its in all gears it just will not pull after 7k and the noise is way more then ever before. LikeI said its like a brake is stuck on but I have looked at all of that to make sure its all rolloing free. As for the cct it may make some noise at low rpms but not at idle could it have just sliped and timing is off a little? AlsoI have not tryed any cleaners.
cliffordsyoung
Dec 17, 2012 04:18 PM
sportracer07
Oct 19, 2010 07:41 PM
esoracco
Jul 29, 2010 11:10 AM
Mr.S7
Jun 4, 2009 01:34 AM
CBrizzle2001xxxx
Oct 11, 2005 08:42 PM
