F2 still doing my nut in
bit more info on my none starting f3. all electrics are working( horn lights blinkers etc) but the engine wont turn over at all. if i jum across the solenoid the starter turns but nothing off the button. all i have done is cut off the connecters going up to the clocks ( theywere not connected to any thing as i run a push bike speedo on the cafe racer) anyone got any ideas? could it be the cdi? goint to solder all the clock connecters back on and see if that makes any difference and add the new clock/rev counter ebay special. any info would be great,
jeff
jeff
Last edited by yorkiejeff; May 6, 2018 at 04:14 AM. Reason: its an f3 not an f2 d'oh
Make sure your battery is fully charged! I would definitely check the connections that are cut off. F3 don’t have clocks unless you did, or bought one with a gauge swap. Check your spark plugs to see if gas is reaching the cylinders.
Clocks = slang for instrument cluster.
RoosterF3
F2 Tech
20
Dec 17, 2010 12:59 PM
