Explain: Radial Brakes
Old Jan 18, 2007 | 02:00 PM
Jaybird180's Avatar
Default Explain: Radial Brakes
I was hoping that someone could explain to me what it means when a bike has radial brakes as opposed to "normal" brakes.
Old Jan 18, 2007 | 02:06 PM
mdfirefighter's Avatar
Default RE: Explain: Radial Brakes
Via Google search for: motorcycle radial brakes
http://www.motorcycledaily.com/13nov...ialbrakes.html
A radially mounted caliper is stiffer, and is better at maintaining alignment with the rotor. This means the pads stay in alignment better, making better contact with the rotor and exerting less lateral force on the rotor while generating less heat for a given pad pressure.
With traditional caliper mount points on the trailing end of the caliper, pad pressure at the leading edge of the caliper has considerable leverage to misalign the caliper in relation to the rotor. Radial mounting takes care of that. Putting a mount at both the leading and trailing end of the caliper, leverage at the leading edge of the pads is reduced to a level that it becomes insignificant.
MDFF
Old Jan 18, 2007 | 03:48 PM
Tahoe SC's Avatar
or are you speaking of the radial pump MC vs. normal?
Old Jan 18, 2007 | 04:01 PM
Jaybird180's Avatar
I'm speaking of in terms of design. For example, my F4i has standard mount brakes, but the RR has radial. The new '07 RR added a radial master cylinder. I understand the goal is better brake feel and stopping power, I just want to know how to be able to tell the difference by sight and understand a little on how they operate.
Northernfirepower
Oct 3, 2008 03:14 PM
grindpunk16
Jul 27, 2007 10:17 AM
Tahoe SC
Oct 5, 2006 03:59 PM
vipkat
Sep 5, 2006 04:56 PM
