exhaust wrap
RE: exhaust wrap
I have a 93 1000F and I wrapped the headers.It seems to help with the engine temp and gives a slight increase in power because it is forcing the heat out the pipe where it goes therefore causing the exhaust gases to vacate faster because of having no where else to go.It took almost 100 feet to cover my header and collector.Yes it does help but you have to drop your header off your bike in order to wrap it correctly and you need to replace the exhaust gaskets when you take it off.
RE: exhaust wrap
from everything i have read exhaust wrap are the worst thing in thw work to do to a header. i bought a 2nd header off ebay and sent it in and had it jethot coated they coat the header inside and out. much better. just wrapping the outside over heats the pipe and it will soon be junk. jet hot is the way to go. i never reach 220 even in stop and go traffic on a 90 degree day
