Ever hear of such a thing?
Old Aug 11, 2008 | 08:57 PM
fast1000f's Avatar
Default Ever hear of such a thing?
I have a 1995 cbr1000f.......Can anyone tell me why I would be able to pull my #4 plug wire, andmy bike still runs with absolutely no sound difference...If I pullmy #1plug(same coil pack) wire, the bike dies instantally. I can put a plug in the wire directly and it sparks like a big dog....scratching my head?????
Old Aug 11, 2008 | 08:59 PM
T_roy's Avatar
Default RE: Ever hear of such a thing?
Bad plug?
Old Aug 11, 2008 | 09:02 PM
fast1000f's Avatar
Wish it were that simple, but no...Replaced plugs, tested coil on each end
cleaned the carbs, tested everything...at a loss.....
Old Aug 12, 2008 | 02:54 AM
DukeCBR's Avatar
I did the same thing on my 900RR when I tested my coils but when I pulled my #4 coil wire, it sounded like a V-Twin and started to chug as the cylinder filled up with gas. Does your bike backfire a lot? Maybe your coil could be fine but your coil wire could be a bit dodgy...
Old Aug 12, 2008 | 07:44 AM
fast1000f's Avatar
you mean from the coil to the plug? thats what im going to check next.when i pull the #4 plug wire from the plug the cylinder should stop firing and the bike should sound differant, but it does not. which means my #4 cylinder was not firing before i pulled the wire.
Old Aug 12, 2008 | 07:50 AM
DukeCBR's Avatar
Thats exactly my sentiments. I hope that is the case and not something with your electrics, cuz thats a biaaatch to debug...
Old Aug 12, 2008 | 07:53 AM
fast1000f's Avatar
i will test later today after work . let you know how it went
Old Aug 12, 2008 | 07:55 AM
DukeCBR's Avatar
Ok cool, good luck...
hawkwind
The Hurricane Saloon
13
Nov 5, 2010 09:47 PM
fosters978
Oct 19, 2010 12:58 PM
Hangfire
Nov 1, 2009 02:38 PM
bindelsf2
May 29, 2008 10:21 PM
KidCr3nshaw
May 14, 2007 11:40 PM
