Engine Rebuild
Old Dec 19, 2007 | 12:51 AM
chuckd's Avatar
Default Engine Rebuild
I am rebuilding a F2 engine that was sitting for a long time. Pulled the head off tonight and found a lot of nastiness on the piston heads and valves. Intake and exhaust ports were not covered while the egine was stored, and they look rusted. Any suggestions? Is a port and polish necessary? I don't need HP gains, just a solid running engine.
Old Dec 19, 2007 | 02:35 AM
Blue Fox's Avatar
Retired Moderator
Default RE: Engine Rebuild
Are you rebuilding the entire engine, or just the top half?
You really don't "need" to port and polish, but since you are rebuilding an engine and going to have everything taken apart anyway, you might as well. I would just take a wire brush attachment for an electric drill and go over everything when it's all taken apart (everything that SHOULD be wire brushed that is.) Remember to re-hone the cylinder walls as well.
Are you just taking it apart and putting it all back together, or are you replacing cylinders, valves, springs, etc, etc. ?
Old Dec 20, 2007 | 01:50 PM
chuckd's Avatar
rebuilding the entire engine, but just replacing what really needs it. I'm on a tight budget, so anything i can do myself is better. This is only the third engine i've ever pulled apart, and I've never seen buildup like this. the engine is locked up, and I'm hesitant to really try to turn it over because I don't want to grind the sludge thats on top of the pistons into my cylinder walls. A friend suggested just using a degreaser. then replace the rings. he also said use the wire brush on the intake and exhaust ports. Is that safe to do? Thanks a lot for your help!!
DTownRunner
Jan 9, 2014 10:03 AM
hioc1098
Apr 20, 2013 02:08 PM
CSXfan
Mar 25, 2011 09:02 PM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
collector
Sep 4, 2007 03:10 PM
