engine rebuild
Old Aug 28, 2007 | 04:10 PM
collector's Avatar
Default engine rebuild
Here are some pics of the first stage of my bikes rebuild. The head was assembled first with the rest afterwards. Let me know what you think.
[IMG]local://upfiles/10939/1DA4FC6E39E640CEA7814E0DD87755AE.jpg[/IMG]
[IMG]local://upfiles/10939/FEF4BBCA7C144375B4D774C9C68EC547.jpg[/IMG]
Old Aug 28, 2007 | 04:37 PM
R1000's Avatar
Default RE: engine rebuild
The engine is cleaner than the dinner table it is located on and that is aguatantiee for a good result
Looking forward tohear your findings and howthe work proceedes.
Whatis the mileage and condition of the engine now ?
Is the head gasket a multi-layer steel gasket?
Old Aug 28, 2007 | 04:42 PM
collector's Avatar
Only got her tested ao sat so only have nearly 100miles, and she feels real smooth, but cant let her loose for a while yet as she needs to be run in (boring I know) But early indications show that there is more power there than there was before..
Yes the gasket is a steel one...
Old Aug 28, 2007 | 04:48 PM
R1000's Avatar
Aaah, you have already rebuilt it? I meant what was the milegae and what was the engine conditionwhen you pulled it? The condition of the different parts, bearing, valve seats etc ?
Old Aug 29, 2007 | 12:28 AM
VeryMotley's Avatar
How long did the rebuild take? Very nice pic. CLEAN motor.
Patrick
Old Aug 29, 2007 | 04:26 AM
BLUE1000F's Avatar
If the whole rebuild looks that clean and you're careful the rebuild/renovation cant be anything but perfect !
Did you do anything to the cylinders/pistons...Overdimension ?
Old Aug 29, 2007 | 03:01 PM
collector's Avatar
Sorry for the delay. Mileage was 72000 and the engine was in a good clean condition, the exhaust valveshad some heat corrosion and alot of carbon on the lower side of all valves. Here are some more pics showing different stages. The pots were honed out as they were in great condition
[IMG]local://upfiles/10939/1F0CE54C9DDE4683828FE62BDD7E1164.jpg[/IMG]
[IMG]local://upfiles/10939/0050303170B849D486468325DBCCF0EC.jpg[/IMG]
[IMG]local://upfiles/10939/EDB381AFFADF439BAD91ED598BBCE72A.jpg[/IMG]
[IMG]local://upfiles/10939/5943CD3486FC44F696B2B82646DC496C.jpg[/IMG]
[IMG]local://upfiles/10939/B58C4137FC50463C820CB2EBF5672EE9.jpg[/IMG]
Old Aug 29, 2007 | 03:30 PM
collector's Avatar
To do the engine was three weeks. Evenings and weekends whenever possible
Old Aug 29, 2007 | 03:33 PM
collector's Avatar
No oversizing done. Just kept to the original engine specs[sm=bounceybounce.gif]
Old Aug 29, 2007 | 03:51 PM
R1000's Avatar
Great job and well done ! So, basically you have changed the rings and grinded the valves and seats, right? Or did you change other stuff also likee.g.main and rod bearings ?
