Engine knock
Old Dec 17, 2008 | 05:36 PM
mlody0's Avatar
Default Engine knock
Ok here is the story, I rode a wheelie for a little too long on my 02 954rr, now the engine knocks a little when revved up. Has anyone been successful with the replacement ofmain and rod bearings before, or should I go with used engine. Thank you for replys
Old Dec 17, 2008 | 07:11 PM
Hurricane rider's Avatar
Default RE: Engine knock
replacing main bearings is totally doable, but rods are much MUCH harder to replace. I'd suggest first though, locate where the knock is coming from, determine what in that area there is that could be causing it, and repair accordingly. a careful and considered approach always gets the best results on these repairs.
Old Dec 17, 2008 | 07:37 PM
TheX's Avatar
ORIGINAL: Hurricane rider
Words of wisdom
Old Dec 18, 2008 | 07:48 AM
mlody0's Avatar
Cool, thanks for the replys. The knock is in the bottom end, I will tear it apart and inspect the crank for any damage.
Old Dec 18, 2008 | 08:19 AM
Shadow's Avatar
You've probably done a main bearing. It may be possible to just waterpaper the crank, but if it's scored, you'll need to have it machined, and fit oversize bearings to compensate. All doable, and a lot cheaper than a new crank !
Moral of the story : You already know the answer to that one ![X(]
929scooby
Sep 15, 2009 02:27 AM
mlody0
Dec 17, 2008 08:19 PM
Rky29
Jul 8, 2008 08:57 AM
Heidegger
May 1, 2007 02:18 PM
sbkrider
Aug 9, 2006 12:11 PM
