Ahh engine knock??
Old Jul 7, 2008 | 02:00 AM
Rky29's Avatar
Default Ahh engine knock??
Whats goin on guys i havent been on here in a while. So as the title states it seems as if i have a knock in my engine. I dont think it was there when i got the bike but im trying to rule out options here. Dont think it matters but the bike seems to get a bit hot when im in stop and go, like the temp gauge goes to about 3/4 the way up after about ten min. of stop and go. But as for the knocking you cant hear anything on startup but after riding for like 10 min and pull up to a light if you rev it a little you hear it a bit but on the "downrev" you can here it pretty clearly. Now i believe i read the cam chain tensioner is notorious for going bad on these bikes but please correct me if im wrong. im putting in 93 shell v power idk what else it could be im hoping its not a rod. help me out guys.
Thanks, Ricky
Old Jul 7, 2008 | 07:26 AM
marc0011's Avatar
Default RE: Ahh engine knock??
Usually the CCT makes noises when the bike is cold. It will make a clear tick noise and goes away as the bike gets warmer.
Old Jul 7, 2008 | 07:40 AM
redzintimidator's Avatar
it does sound like a little of a rod knock...release the pressure on the crank(downrev) and it knocks a little...start with the cct, if that helps..great then it was that. if its not you may have to dig into your engine
Old Jul 7, 2008 | 12:06 PM
Rky29's Avatar
ORIGINAL: redzintimidator
Nooo, damnit I was really hoping it wasnt that. I might as well buy a new engine if it continues to get worse...
Old Jul 7, 2008 | 01:50 PM
i really dont know though...dont count on me being right, it doesnt happen too often
Old Jul 7, 2008 | 09:55 PM
Mikes03954RR's Avatar
These bike are notorious for bad CCT. How many miles are on it? I had the same problem with my 954. I got the CCT changed and it went away. Do this and see if it helps. If not you got some other kind of problem.
Old Jul 7, 2008 | 11:17 PM
Rky29's Avatar
Ive only got roughly 11.5k miles on it...thats what i thought a little early for a knock. But yeah ill give the CCT a try hopefully alls well, thanks for the help.
Old Jul 8, 2008 | 08:57 AM
marc0011's Avatar
If it ends up not being the CCT, I wouldn't go out replace the engine. I would open it up and look for the bearing that is failing. It would be a cheaper fix than replacing the whole engine. By the way, it could also be a bearing in the transmission.
929scooby
Sep 15, 2009 02:27 AM
mlody0
Dec 18, 2008 08:19 AM
mlody0
Dec 17, 2008 08:19 PM
Heidegger
May 1, 2007 02:18 PM
sbkrider
Aug 9, 2006 12:11 PM
