empty gas tank
Old Nov 23, 2006 | 09:54 AM
mikeyvis's Avatar
Default empty gas tank
trying to empty gas tank with fuel lines off using the petcock but no gas will drain out what am i doing wrong.
Old Nov 23, 2006 | 11:10 AM
Demon RR's Avatar
Default RE: empty gas tank
you may need to open up the fuel filler cap. this will creat a vacuum and allow the fuel to flow out.
Old Nov 25, 2006 | 02:30 AM
bushmasterAR15's Avatar
+1
Old Nov 25, 2006 | 09:43 PM
mdfirefighter's Avatar
My 94 1000F needs vaccum on the petcock to drain fuel, I used a brake bleeder to apply vaccum and it flows just fine.
MDFF
Old Nov 26, 2006 | 06:35 PM
knightslugger's Avatar
fire fighter is correct. if the petcock is vacuum actuated, the valve inside wont allow fuel to flow unless there is a vacuum. there are two lines, correct? generally, the smaller of the two line is the vacuum line. if you suck on that (to create a vacuum) i'll bet you a case of your fav. that fuel will flow out the other tube.
Old Dec 1, 2006 | 02:55 PM
big10donjuan's Avatar
ORIGINAL: knightslugger
+1
JamieDenny
Mar 25, 2014 03:44 PM
Sulayman95
May 2, 2013 09:38 AM
otello
Apr 8, 2009 02:59 AM
F4Isvt
Oct 12, 2007 07:51 PM
