electrical problems-found the fix
Old Jun 6, 2006 | 04:20 PM
MuNkY6913's Avatar
Default electrical problems-found the fix
i just bought this bike, a 96 cbr 600f3, it's been wrecked a couple of times by the guy i bought if from. the battery was shot, i replaced it. for some reason it wasn't getting power through the line to the ingnition switch, so i ran a new wire strait from the + term on the battery to the hot point on the ingnition switch. with that and the new battery it started up fine and i was able to ride it for about 25 mins after wich i turned it off for the night, just wanted to see if it worked. so today i go out and start it, it starts and everything, i get on the road and about 4 or five blocks away it's starts sputtering and then dies. i'm like what the f*&%^, i try and start it back up and it has no juice what so ever, not even enough for the lights to come on, wich 5 mins earlier were bright. any comments or suggestions would be much appreciated, thanx-------i didn't even need to run that wire, there was a fuse right in front of the battery, under the gas tank, in some sort of harness, 30A fuse was blown. i replaced it and reconnected the wire i cut at the ignition switch, took the one i ran out and it started up fine and is running good with the "old" battery (turns out it wasn't shot), so now i can take the new one back. thanks for the input guys.
Old Jun 6, 2006 | 07:37 PM
cruzinhb714's Avatar
Default RE: electrical problems got me
Magnito / Alternator any good? Might not be charging the battery, so its just draining untill it dies. ? Maybe.
Old Jun 7, 2006 | 12:36 AM
slowpoke's Avatar
You had the right idea, but the wrong execution. The line from the battery has to go to the fuse box. The ignition switch uses a starter relay because the starter needs full power, but the ignition switch wiring can't handle that full power. Hence a relay to handle the juice. You probably fried something. I would probably start with the wiring diagram for the F3 and do it right so you don't burn the bike.
Old Jun 7, 2006 | 05:46 AM
MuNkY6913's Avatar
any suggestions on the where to find a good diagram or schematic
subyman1440
F2 Tech
Feb 20, 2012 09:53 PM
jt2737
Jul 25, 2010 11:02 AM
f2cbrf4i
F2 Tech
Jun 11, 2010 06:28 PM
RoosterF3
F2 Tech
May 5, 2010 06:47 AM
chadj1980
Jun 3, 2009 01:03 AM
