electrical problems-found the fix
i just bought this bike, a 96 cbr 600f3, it's been wrecked a couple of times by the guy i bought if from. the battery was shot, i replaced it. for some reason it wasn't getting power through the line to the ingnition switch, so i ran a new wire strait from the + term on the battery to the hot point on the ingnition switch. with that and the new battery it started up fine and i was able to ride it for about 25 mins after wich i turned it off for the night, just wanted to see if it worked. so today i go out and start it, it starts and everything, i get on the road and about 4 or five blocks away it's starts sputtering and then dies. i'm like what the f*&%^, i try and start it back up and it has no juice what so ever, not even enough for the lights to come on, wich 5 mins earlier were bright. any comments or suggestions would be much appreciated, thanx-------i didn't even need to run that wire, there was a fuse right in front of the battery, under the gas tank, in some sort of harness, 30A fuse was blown. i replaced it and reconnected the wire i cut at the ignition switch, took the one i ran out and it started up fine and is running good with the "old" battery (turns out it wasn't shot), so now i can take the new one back. thanks for the input guys.
You had the right idea, but the wrong execution. The line from the battery has to go to the fuse box. The ignition switch uses a starter relay because the starter needs full power, but the ignition switch wiring can't handle that full power. Hence a relay to handle the juice. You probably fried something. I would probably start with the wiring diagram for the F3 and do it right so you don't burn the bike.
