Electrical Problem (Starter??)
Old Mar 8, 2010 | 09:19 PM
Just a quick reply as I read. Each of the checks I'm wanting you to make, you should be leaving the black clip for your probe on the negative terminal of the battery, or the frame. You only move the probe end that has the light. Think of the wiring harness as a hose full of water that's under pressure. When you put the probe into a connector, your checking to see if there is any pressure. I hope that makes sense.
I need to read through your response a couple times to understand what you're saying.
Old Mar 8, 2010 | 09:54 PM
dylan-pb's Avatar
Default Welll Now Im Really Confused? haha
So I did what you said (good pipe analogy haha) I had one side connected to the negitive battery terminal and the other connected to the silicon rectifier (the darker green/red side) and it lights up? But only on that one side? Sooo now i dont really know what to make of all this here is that photo..
Old Mar 8, 2010 | 11:04 PM
dylan-pb's Avatar
Smile Amazing thanks going out to Bill :D
Thanks to Bill I got this figured out.. haha or at least a lot closer to it
Thank you so much an God Bless
Old Mar 9, 2010 | 07:26 AM
I'm glad you were able to get things worked out. So that everyone here knows what happend and the cause, I'll fill in some details. The bike has had the wiring harness replaced. It also doesn't have a gauge cluster, so there are no indicator lights of any kind. It turn out that the bike is not in neutral, in fact that will be one of the next challanges after he gets it started. Anyway, the bike won't start if it's not in neutral. Unless you pull in on the clutch lever and have the side stand in the up position. After doing those 2 things, the starter worked and all was well. We did a Skype session and Dylan-pb had a video camera on his side so that I could see the full picture of what was going on.
Congratulations and good luck getting her running.
Old Mar 1, 2018 | 07:49 PM
streetfighter7's Avatar
Do you have a relay for your headlights? I have a 89
kwood
Jun 1, 2020 09:53 AM
600$tunter
F2 Tech
Oct 9, 2011 12:00 AM
FuzzyWuzzyBear
F2 Tech
Mar 22, 2010 05:39 PM
Klink
Oct 21, 2008 11:21 AM
Dingsbums
May 6, 2008 08:55 PM
