Electrical problem with 94 F2
Old Mar 14, 2011 | 05:34 PM
F2Supersport's Avatar
Default Electrical problem with 94 F2
Hey guys I hope you can help me out here. I am currently in the process of taking the stock mirrors off and putting new ones on that have the integrated LEDs . I did the necessary prep work to get the mirrors to hook into the old front blinker wires. I had the mirrors hooked up to test them and everything was functioning perfectly. Mounted one of the mirrors and re checked to make sure it worked and all of a sudden they stopped working
Checked the small fuse box on the throttle side of the bike and discovered a burnt out 15 amp fuse so I replaced it And nothing. So currently I can turn the key on , start the bike and I have my high beam and low beams that's it. No blinkers, no taillight or brakelight , no horn, nothing and none of the dash lights work except for the high beam indicator.
What could be causing this
Any help would be greatly appreciated.
Old Mar 14, 2011 | 05:40 PM
The lights stopped working while I had the key turned on I accidentally hit the blinker switch for the wrong side (the one not hooked up) and the positive and negative ends could have been touching. Are there fuses or something in more than one spot on the bike?!?!?
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
