electrical problem
Old May 21, 2012 | 08:35 PM
stevens09's Avatar
Default electrical problem
i have a 2001 600f4i... got it 2 weeks ago and i am a new rider so dont know much bout them.. evrything ran good till last night when i went to go home... what happ was when i let go of ignition switch it just died automatically. rolled back some so i can push it up my friends driveway and leave there for the night. started up but have no headlights now, plus when i turn my turn signals on it dies automatically... if anyone has any ideas please let me know
Old May 22, 2012 | 01:10 AM
vfrman's Avatar
Party Animal, ROTM June 2014
Time to check your charging system. Sounds like your reg/rec went out and isn't charging the battery. The bike ran off the battery until it was dead and now the bike is done.
Get the battery fully recharged and then test your system using this:
http://www.electrosport.com/media/pd...ng-diagram.pdf
Old May 22, 2012 | 01:00 PM
jveach's Avatar
Also check you headlight wiring harness. The F4i has a bad tendency for the headlight wire harness plug to come loose. When this happens bike will just die and not run. They have a safety switch( which shuts bike off if you drop it ) it is part of the headlight harness. So therefor when the plug comes loose, Bike doesn't run.
Old May 22, 2012 | 03:03 PM
stevens09's Avatar
well tested the battery and its good.... the bike will run but as soon as i turn a turn signal on it will die... ima go check the wire harness so if there is a short in it or somethin
Old May 22, 2012 | 03:09 PM
stevens09's Avatar
well i just got home from work and strted bike up everything works now, so im takin it theres a short in the wire harness or somethin
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
