Electrical Problem
Old Jun 15, 2010 | 03:13 PM
aguara's Avatar
Exclamation Electrical Problem
Hi people! I have a CBR 1000 american version and the problem is with the electric part... If hot the machine, the battery start discharging and can't restart the motorcycle
I need help
Thanks!
Old Jun 15, 2010 | 03:33 PM
justasquid's Avatar
You didnt mention what 1000 model you have. if its the 1000RR 04-07, model, they had some issues with the stator going bad. Test the stator would be my first suggestion.
Old Jun 15, 2010 | 03:46 PM
aguara's Avatar
The model is CBR1000F
Old Jun 15, 2010 | 04:48 PM
agent orange's Avatar
i had this problem with my f4i.. when it was cold it started and ran fine.. but as soon as it got hot and i shut it off it would not restart until it cooled down.. is that whats happening with you?
Old Jun 15, 2010 | 05:40 PM
aguara's Avatar
yes ... likewise... you can will solve this problem?
Old Jun 19, 2010 | 12:01 PM
aguara's Avatar
go! please help me
Old Jun 21, 2010 | 02:21 AM
jweezyf's Avatar
I have a simular problem, and I have the cbr 1000rr 06. I just replaced the battery, now it makes a clicking sound that comes from what looks like a relay by the battery. I put my battery charger on it to check it and it still wont start. the only way right now I can start it is to push start it.
Old Jun 21, 2010 | 11:19 AM
aguara's Avatar
There must be some solution... what's that is the question?
Old Jun 21, 2010 | 11:21 PM
justasquid's Avatar
have you checked the stator yet? You can measure the resistance across the 3 leads coming from the stator to tell if its bad. I would check it when its cold and when its warm. Im not sure what your specific resistance in ohms is suppose to be, but they should all fall in a certain range. Normally, when a rectifier goes bad, one set will be out of range. Measure across 1&2, across 2&3, and across 1&3. a call to a dealer should tell you what the correct resistance.
If that checks good. Next time the bike is warm. check to see how hot the rectifier is. If its extremly hot, its probably bad. rectifiers will get warm, but not hot. Also, check the plug on the rectifier to make sure no wires are burned. Unplug it and check the plug carefully. If any wires look burned, or the plug looks like it has been melted, replace the rectifier.
Also, another thing to consider is the possibility of the battery itself is at fault. Next time the battery starts to discharge, feel how hot the battery is, and listen closely to make sure you don't hear any sizzling sounds.
04-07 1000RR's have issues with the stator overheating and failing. Once they fail, they need to be replaced. Test it in the same manner as listed above by measuring the resistance across all 3 leads. The clicking your hearing is the relay for the starter trying to kick on the starter. The reason it is only clicking is because it does not have enough power to start. Meaning the battery does not have enough voltage, or your connections are loose. If the battery is fully charged, there must be a weak connection somewhere.
Old Jun 22, 2010 | 04:47 PM
jweezyf's Avatar
I think I found the problem its the relay switch.
01daell
Sep 2, 2021 07:46 AM
kwood
Jun 1, 2020 09:53 AM
vfrman
Nov 16, 2008 10:06 AM
hridlehuber
Apr 5, 2006 04:11 AM
dunn929
Dec 6, 2005 12:50 PM
