Electrical ?????
Old Mar 10, 2012 | 06:01 PM
ShaunCBR's Avatar
New Member
Default Electrical ?????
I just changed the fairing on my 2008 cbr1000. after rehooking up all the wires i have no power. battery is charged. What do i do
Old Mar 10, 2012 | 07:19 PM
74demon's Avatar
recheck that you didn't miss a connector, the battery cables are clean and tight, and check the "main" fuse. the main fuse is located outside the fuse box. follow the positive cable from the battery and you will find it, probably under a cover.
good luck...
Old Mar 10, 2012 | 08:37 PM
On fuel injected bikes there is a Bank Angle sensor that kills the bike in case of a wreck. My understanding is that they're usually located somewhere in the front fairing. If you put it back in the wrong way, the bike can think it's on it's side and not be able to start or run. My bikes are carbureted, so I don't have one of them.
Old Mar 10, 2012 | 09:32 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I've read several threads where the BAS was installed upside-down and it wouldn't start. I don't know if the engine would still crank or not. He says it has no power, like there's no lights or anything when he turns the key on.
kani73
Jul 31, 2011 04:25 PM
zapp109
Apr 1, 2010 12:18 PM
drown42
Aug 26, 2009 04:06 PM
skitzofrenzy
Sep 22, 2008 04:21 PM
travsstuff
Dec 4, 2007 11:51 PM
