Dual lo / high beam laights
Old Aug 27, 2008 | 07:15 PM
phsycleRR's Avatar
Default Dual lo / high beam laights
Curious about BikeLites dual light system. Will this give me 2 lo beam and 2 high beam. Will this draw to much power or are there any other negatives to that sytem?????????????????
Old Aug 27, 2008 | 08:40 PM
Blue Fox's Avatar
Retired Moderator
Default RE: Dual lo / high beam laights
If your planning on installing it on an RR (either 600 or 1000) forget it. The headlamp reflectors weren't designed for a dual-filament bulb, they were designed for a single filament. The way the headlamp reflects the light is what makes it a low/high beam.......not the brightness of the bulb. Pull a couple feet up to a wall and you can see for yourself. The lowbeam is flat and wide. The highbeam is more concentrated into a smaller area.........even though they are using the exact same bulb.
Old Aug 28, 2008 | 03:49 PM
MidnightG35X's Avatar
Same goes for an F4i
Old Aug 28, 2008 | 05:05 PM
phsycleRR's Avatar
What if I put on Halo eyes or Angel eyes
Old Aug 30, 2008 | 06:08 PM
02cbrf4i4u's Avatar
Could you put a low beam reflector on the high beam side?
Old Sep 1, 2008 | 03:16 PM
Ark Dan's Avatar
I hope there is a high beam on the market better than stock, I bought a new 06 and it has the worst lights of any of my last 3 or 4 bikes.
Old Sep 2, 2008 | 01:21 AM
justasquid's Avatar
No doubt they are horrible. You only have 2 55 watt bulbs when the high is on, and only one of them aims higher... it sucks for sure. I did change mine over to silvania's ultra bulbs and they do make a difference. Its nowhere near like my firends 05 R1... but is an improvement.
RobHMS
Apr 12, 2013 07:46 AM
hss2010
Mar 7, 2012 01:46 PM
buknoy
Jul 1, 2009 06:18 PM
jerbear
Aug 29, 2008 08:52 AM
ddaren
Nov 26, 2006 07:02 PM
