low beam high beam, broken
Old Aug 28, 2008 | 01:12 PM
jerbear's Avatar
Default low beam high beam, broken
When I switch between low and high beams my headlight sometimes goes out all together. I then have to toggle the switch back and fourth a handful of times until the lights come back. Would you guys vote switch? or something else is broken before I tear it all apart?
Thanks.
Old Aug 28, 2008 | 04:27 PM
MI900RR's Avatar
Default RE: low beam high beam, broken
Definitely the switch
Old Aug 28, 2008 | 07:12 PM
raidersjoe's Avatar
no way i just had the same problem, first the fan wasnt working then the low beam, then a read left signal light, then the high beam but if i toggled it back n forth sometimes it would work. my buddy(mechanic) came over yesterday and traced all the wiring to the left read lcd signal light connector wasnt making a complete contact therefore it wasnt grounding properly. he replaced it with a butt connector and everything works now.... so wiggle all the wirring harness plugins before you dish out $$$ ona a new switch....
Old Aug 29, 2008 | 08:52 AM
gixxereater's Avatar
The contact is dirty. It's not BROKEN as in shot. Take it apart and clean it with contact cleaner (electronic, not eye).
Mine did the same thing after riding in the rain alot one season, the corrosion got it and would not make a good contact. Clean it and all will be well with the world.
ObsidianOne
Aug 9, 2015 01:34 AM
hss2010
Mar 7, 2012 01:46 PM
buknoy
Jul 1, 2009 06:18 PM
justasquid
Oct 7, 2008 03:21 AM
ddaren
Nov 26, 2006 07:02 PM
