Drive Chain Bolt Adjustment Tips?
Old Nov 9, 2005 | 02:52 AM
cjbettis's Avatar
Default Drive Chain Bolt Adjustment Tips?
I just learned a tip about tightening the rear axel nut...you only tighten it from a 10pm-2am position..cause tightening away from the drive chain bolt can creat space. Any tips for making sure both drive chain adjusting bolts are exactly in the same position (ie counting the number of rotations, looking at the index marks, what is the very BEST)?
Old Nov 9, 2005 | 08:40 AM
doncollins's Avatar
Retired Administrator
Default RE: Drive Chain Bolt Adjustment Tips?
good tip, I never put much thought into it because I use the index marks as my guide. I'll have to remember to try this, I'm due to clean my chain and adjust as needed.
Old Nov 9, 2005 | 05:35 PM
Tahoe SC's Avatar
i count the rotations...but remember to pull back on the tire when you tighten otherwise, there's more tension on the left side (shifter side)
Old Nov 9, 2005 | 11:46 PM
doncollins's Avatar
Am I wrong to assume the index marks are accurate? Should I advance the adjustment all the way in and then count the turns? I ordered my 15T drive sprocket so I’ll be playing around with this in a few days.
Old Nov 10, 2005 | 01:15 PM
Tahoe SC's Avatar
adjust all the way in and adjust the clips to match and then count the turns. you just don't know if the clips moved during riding or what not.
Old Nov 11, 2005 | 01:22 AM
cjbettis's Avatar
Just got a 32mm socket so can redo the rear end allignment. Gonna take your advice and count the rotations. Don't want early wear on the chain, sprockets, and rear tire....Thanks!!
shraz
How-To: Mechanical
Mar 13, 2012 11:18 AM
Incompatible
Jan 10, 2012 07:32 PM
mrchips
Oct 13, 2011 03:50 AM
MC_spirited
Apr 17, 2009 11:05 PM
macfable
Apr 14, 2008 05:51 PM
