Did I buy the wrong replacement rad. cap?
Old Aug 30, 2007 | 04:46 PM
travisgarrison's Avatar
Default Did I buy the wrong replacement rad. cap?
Someone on this forum said that the STANT 11227 radiator cap works for the CBR. If fit great but I just ran across the radiator section of the shop manual and the radiator cap test section says that the radiator cap should be able to hold 16-20psi for 6 seconds, or replace it. The STANT cap has 13psi printed on it. So did I buy a "weak" cap? If so, does anyone have a STANT part number for one that will hold 16 or 18psi? (The shop manual said above 20psi will cause damage).
Old Aug 31, 2007 | 03:05 AM
demonchild's Avatar
Default RE: Did I buy the wrong replacement rad. cap?
In this hot weather I would think that you want the correct amount of psi as per the manual, however, I would not sweat it unless you overheat.
Old Aug 31, 2007 | 03:09 AM
demonchild's Avatar
at 13 psi and a 50 50 mix, you should be good for about 260 degrees. I wouldnt worry about the cap you bought.
mark5009
Mar 7, 2008 12:53 PM
Asmittie84
Jan 5, 2008 01:48 PM
Rubicon on 38s
Nov 17, 2007 05:18 PM
Skater
Jun 3, 2006 03:13 AM
Loomis
May 8, 2006 01:23 PM
