Did I buy the wrong replacement rad. cap?
Someone on this forum said that the STANT 11227 radiator cap works for the CBR. If fit great but I just ran across the radiator section of the shop manual and the radiator cap test section says that the radiator cap should be able to hold 16-20psi for 6 seconds, or replace it. The STANT cap has 13psi printed on it. So did I buy a "weak" cap? If so, does anyone have a STANT part number for one that will hold 16 or 18psi? (The shop manual said above 20psi will cause damage).
