Dead Speedo
Is it the cluster not working as in no lights or anything? or is just the speedometer...
If its just the speedo, my first check would be the cable. I think that model has the speedo cable running down to the front tire. I would pull the cable from the cluster and rotate your front wheel. If it doesnt turn, you know your problem is either the cable or the drive. If it does, its in your cluster.
If its the entire cluster, check your fuses.
WhiteHawk
05-30-2013 09:56 PM
