Curious?
Old May 27, 2009 | 10:09 AM
King Klong's Avatar
Default Curious?
Anyone ever hard wired their fan to a switch? I ride in a hot area, and it would be nice to just cut the fan on whenever I know it will be needed.
Old May 27, 2009 | 05:20 PM
marc0011's Avatar
Seen it done of F3s, but I really don't recommend it. If you're running hot because of idling through traffic, that means that your charging system will be put under additional strain from running the fan excessively.
Old May 27, 2009 | 05:29 PM
nutter's Avatar
Unhappy
your bike will know when to turn the fan on seems a bit silly wanting to put it on a manual switch what happens if you forget to turn it on you get cooked motor
Old May 27, 2009 | 05:43 PM
xjoewhitex's Avatar
Yea thats a very good point, you may not think you would forget but maybe you had a bad day and just sitting in traffic and you look down and your motor is 300*. Id say just leave it stock, when it gets hot it kicks on..
Old May 28, 2009 | 06:57 AM
Falqon's Avatar
I think I'd just jump the sensor coming out of your radiator with the switch, no need to mess with hot wires that way.
That being said, I wouldn't do it because I don't see the advantage of you doing it over the switch doing it. I live in the middle of a lot of traffic and it is annoying after a few lights it's always on but hey, keeps the engine alive.
Old Jun 16, 2009 | 07:15 PM
jfizz84's Avatar
my original fan blew, so i hooked up a 12 fan to it to a toggle and let me tell ya. it sucks. first u have to drill a hole somewhere for the toggle. then u got more wires running around. plus like someone else said u dont wanna forget to turn it on, the temps jump up quick esp when uve been riding. so now i just ride without a fan. i stay outta traffic which isnt hard to do since i live int he sticks, alotta 50-55mph country roads and keep an eye on it. if i start getting hot, i just pull over and have a butt. my advice tho, keep it stock. its a perfect design
Old Jun 17, 2009 | 09:04 AM
johnnyx's Avatar
I did it. I have it wired so when the toggle is off, it relies on the temperature relay to activate the fan (like normal). Turning the switch on just forces the fan on. I did it because I love riding at night, and up where I am it often gets down into the 40's. I throw the fan on to blow the heat back at myself and warm up a bit. Sounds hilarious, but man, its NICE when your legs are going numb.
Sounds like you're doing it to DISABLE the fan at certain times. I wouldn't reccomend that AT ALL. You'd be amazed how fast these engins can overheat while idling. Be happy you at least have a liquid-cooled bike, and not one of those massive air-cooled engines on the cruisers. Those things make you feel like you're in the bowels of hell, just sitting at a traffic light.
Old Jun 18, 2009 | 07:07 AM
King Klong's Avatar
i wouldn't do it to disable the fan. i would want it how you have it, if i were to do it johnnyx. i was considering doing it because i know when my fan is going to come on meaning i know when i am going to have to sit at a lite for a long time, or ride at less than 35 for a long distance. i'd like to turn it on before it reaches that 212 mark.
Old Jun 18, 2009 | 11:11 AM
johnnyx's Avatar
212 is the optimal engine temprature, IIRC. The fan shouldn't be on before that, anyway.
But, to answer your question:
You just need some wire and a 3-pole, 2-position switch. Wire Position 1 as FUSE > SWITCH > TEMP. RELAY, and Position 2 as FUSE > SWITCH > FAN.
Pos 1 is normal, "stock" functionality, allowing the bike to regulate the fan on its own
Pos 2 forces the fan on, no matter what.
EpicLife
Jun 13, 2012 08:46 PM
spazinout777
Jun 7, 2009 06:32 AM
NY Erion929
Oct 4, 2008 06:14 PM
peejay
Apr 20, 2005 10:38 PM
