Crooked front wheel
I have a 929 and when the handle bars are straight the wheels faces to right...how can I straighten this problem or check components to make sure nothing bent?...thanks
I am not sure what bolts I need to loosen to try and straighten between my legs...
https://cbrforum.com/m_32039/tm.htm
Maybe this link will help even though it's a 929. Loosen the lower triple clamp, axle bolt and pinch bolts. Should be able to twist tire.
Here is another thread on the subject.
https://cbrforum.com/m_14627/tm.htm
No worries !!! My bike had the exact same problem when I got it from the dealership.... It pretty much came from rushed set up, or a good bump. just loosen everything from the lower triple clamp down and adjust it until you`re happy. That`s all the shop did for me, and I went home and did it again because they still didn`t get it right. (Then I re-tourqed everything on the bike because I was afraid of what else they rushed through.....)
japanese900rr
Aug 15, 2006 11:52 PM
