crank wont turn, HELP PLEASE!!
Old Aug 1, 2006 | 11:51 PM
little_leon60's Avatar
Default crank wont turn, HELP PLEASE!!
i bought a 1993 f2 for $500 with only 16k on it and it had a stripped spark plug hole.. i took off the head and had it fixed and installed then when i was installing the cams/camchain sprockets i somehow screwed up the timing with the in/ex marks on the head surface with the t mark to the dot on the cover.... when i went to fix this i went to turn the crank and it wouldnt turn... what could be causing this? i would appreciate some help asap!! thanks
Old Aug 2, 2006 | 01:23 AM
slowpoke's Avatar
Default RE: crank wont turn, HELP PLEASE!!
I would take the cams off and see if the crank turns. Then I would time the cams. The Haynes manual describes the procedure.
Old Aug 3, 2006 | 09:31 PM
CWF340's Avatar
sounds like you have piston to valve contact, be very careful you could bend a valve if you try to force the crank.
VR6T
May 6, 2018 08:17 PM
ndscbrf3
Dec 12, 2011 05:16 PM
thecoop20
Aug 12, 2011 01:20 PM
mralbdamminc
Apr 10, 2009 11:27 PM
little_leon60
Aug 2, 2006 08:47 AM
