crank wont turn, HELP PLEASE!!
i bought a 1993 f2 for $500 with only 16k on it and it had a stripped spark plug hole.. i took off the head and had it fixed and installed then when i was installing the cams/camchain sprockets i somehow screwed up the timing with the in/ex marks on the head surface with the t mark to the dot on the cover.... when i went to fix this i went to turn the crank and it wouldnt turn... what could be causing this? i would appreciate some help asap!! thanks
