cooling system
Old Mar 25, 2009 | 07:12 PM
Stiggs's Avatar
Default cooling system
Does anyone know the standard running temp. of a 1999 CBR900RR ??
New bike to me and it was very low on coolant when I purchased it. Did the oil and brake fluid change tonight and filled the coolant?? just wanted to make sure everything is working. It seem to get to 218 and then the fan kicks on. Is this typical?? any help would be great.. thanks to all
Old Mar 26, 2009 | 03:01 AM
Incognito's Avatar
Official CBRF Welcome Crew Undercover Agent
That sounds about right, I've noticed these bikes should be running at around 225˚F ~ 230˚F when they're not moving. My fan kicks on at 223˚F ('03 F4i). You might as well flush your coolant while you're at it. All I did was remove the hose from the water pump (lower left side). The Prestone Extended Life is OK to use & only $13. BTW, up on top are downloadable service manuals.
Old Mar 26, 2009 | 07:17 AM
UncleSmokey's Avatar
ehhh, I wouldn't put car antifreeze in your bike it has sillica or how ever you say it in the antifreeze.
Old Mar 26, 2009 | 01:06 PM
Incognito's Avatar
Wink
Yep, make sure if you do use car stuff, that it doesn't contain silicate and is safe for aluminum.
Old Mar 26, 2009 | 02:29 PM
nessxp's Avatar
That seems about right. My 03 600rr heats up till about 223 before the fan comes on. I usualy dont ride it untill the fan comes on let it warm up to a decent temp. Good luck with it
Old Mar 27, 2009 | 06:52 AM
Stiggs's Avatar
thanks for the reply's this is all new to me so it is a big help to know that there are people who can help so thanks to all
tug686spd
May 4, 2010 09:24 PM
Michalis
Mar 25, 2009 10:50 AM
UDFxRookie
Mar 2, 2008 10:26 PM
OZ.CBR600RR
May 7, 2007 02:37 AM
