coolant level help
Old Nov 11, 2017 | 12:15 AM
cbrbike's Avatar
Question coolant level help
hi i need a little help with my baby blade.
4 months ago i changed my coolant. then yesterday i checked my coolant level when the engine was cold. the level hasn't changed in the coolant reservoir. so there was no issue at the reservoir side. but then i opened the radiator cap and checked the level. the level has dropped a bit. the level could be seen through the radiator cap opening. it was at the bottom of the radiator filler neck (a picture attached below). i have no visible external leaks. no smoke from the exhaust too.
anyway i put some coolant there to fill it up. so is this something to worry about? bike runs fine no heat problem at all. but as i recall, before i noticed this the coolant level was at the top of the filler neck every time i opened and checked it. this is the first time i noticed this kind of level drop. thank you
Old Nov 11, 2017 | 08:06 AM
74demon's Avatar
That's about as full as it gets. Don't worry about it.
Old Nov 11, 2017 | 04:13 PM
Hawkwind2016's Avatar
There could also have been a little air left in the system from when you changed the coolant.
Old Nov 11, 2017 | 07:31 PM
cbrbike's Avatar
thank you
got it. thank you
GMC_Guy77
Sep 22, 2011 08:15 AM
philthethrillohio
Jul 31, 2009 04:07 AM
f44life
Jul 5, 2009 01:45 AM
Bumble Bee
Feb 26, 2008 07:53 AM
dajark
Jun 28, 2006 08:56 PM
