Coolant leaking from waterpump?
Old May 22, 2007 | 11:19 AM
byc_panty's Avatar
Default RE: Coolant leaking from waterpump?
ok thanks for the replies....
i have more questions...
what s the impellar that i need to turn?? and what oil are you referring to?
sorry im a newb... i might even have to wait 3 weeks as its a back order here wehre i live...so if anyone knows where i can find one fast please help!!
thanks
Old May 22, 2007 | 11:39 AM
byc_panty's Avatar
are all 1995, 96, 97, 98 cbr f3 water pump the same fit???
Old May 22, 2007 | 12:33 PM
Tahoe SC's Avatar
not sure of the fit...
but as for oil...it's the engine oil. the shaft of the pump inserts to an area just above the oil pan...and is lubricated by the oil. when you remove the pump, oil comes out, so either drain the oil or sit the bike straight up.
as for the impellar...you'll see that it has a knotch in it like this --. you need to line that up with the receving side or else it won't go on. just get a flashlight and peek in there and then just turn the shaft to match up.
Old May 22, 2007 | 01:26 PM
byc_panty's Avatar
ok thanks alot
Old May 22, 2007 | 03:32 PM
byc_panty's Avatar
tohoe im assuming when you orderd it from ebay that it said it came from the year of your bike model?
i just talked to a guy from a nearby bike shop and said that 95 and 96 water pumps are the same but the 97 and 98 are different...
i see one on ebay right now for 50 and im still hesitating!!!
Old May 22, 2007 | 04:20 PM
Tahoe SC's Avatar
i think he's right.
the 95-96 and 97-98 part numbers are different on ronayers.com microfiche.
Old May 24, 2007 | 10:30 AM
byc_panty's Avatar
guys can i just replace the internal seals instead of buying a new water pump??
Old May 24, 2007 | 10:31 AM
byc_panty's Avatar
frigg on a side note i just recived a manual cct from the states and the dam cod cost is the same as the acutal product!
Old May 27, 2007 | 03:22 AM
byc_panty's Avatar
ok guys i installed a used water pump from a salvage yard.... and it seems like the leak isnt completely gone....after riding for a while and letting the bike sit..it seems like i can get some coolant on my fingers wehn i touch it....
i havent investigated whether its from the weeping hole or from the gasket seal yet...
i used prestones pre mixed coolant/antifreeze stuff..for cars...but it says its silicate free so i used it
and the color is orange instead of green.... someone on this thread said not to use automotive antifreeze...
do you guys know if this is safe?
Old Sep 21, 2020 | 10:19 AM
Daleton's Avatar
Originally Posted by Dan1220
Well, as it says...i have some coolant dripping from the bottom of my water pump on my f2. Its not alot at all, just a few drops but its enough for me to want to fix it. Do i just need to replace the O-ring inside the water pump? Help is appreciated
Thanks,
Dan
​​​​​​ can you replace the seals inside the water pump instead of replacing the whole water pump ?
J187
Jul 19, 2022 09:04 AM
kapsiak
May 6, 2012 12:41 AM
J187
Aug 28, 2010 02:41 PM
jam0837
Mar 12, 2009 04:00 PM
Conna
May 26, 2008 04:11 PM
