Clutch Return Spring Install.....
Hey guys... I recently posted "what is this" and found out it was a clutch return spring... well, i was looking through my pdf manual and found I should be able to disconnect the clutch cable then do about a 180 counter clockwise with the pin and it should then pull out.... would this work? I talked to my honda dealer, and he said there are a lot of them like that... This would be awesome due to the fact I wouldnt have to completely take my cover off and saves replacing the gasket, draining the oil, and replenishing the oil supply....
thanks for any help guys,
Chris
Chris
