clutch question
Old Feb 6, 2008 | 06:20 AM
SNOWMAN's Avatar
Default clutch question
i have a 929 with 15,000 on it. the clutch dosnt start grabbing tell the lever is almost out. the ajustment screw on the lever is all the way in and there is no play in the lever at all. is there another ajustment that can be made at the clutch assyitself ? i would like it to grab alot quicker on releasing the clutch. the clutch dosnt seem to be slipping so i dont thing it is bad. thanks
Old Feb 6, 2008 | 07:35 AM
thirdgenlxi's Avatar
Ironmang
Default RE: clutch question
Adjust your clutch lever so you have some freeplay and it'll grab sooner. Having it too tight (no freeplay) will only cause your release bearing to burn up quicker, and if really tight could make the clutch slip and burn that up to
Old Feb 6, 2008 | 07:52 AM
SNOWMAN's Avatar
thers no ajustment left at the lever. the ajusters are bottomed out at the lever. if i screw them the other way it will just make it even tighter. thats why i was wondering if there was another way to ajust it. i just bought the bike a week ago. i bought from the orignal owner but he dosnt have a clue.
Old Feb 6, 2008 | 08:56 AM
SNOWMAN's Avatar
i guess what i want to know is can you adjust the clutch at the motor
Old Feb 6, 2008 | 10:33 AM
KidCr3nshaw's Avatar
Yes, the enging mounted adjustment is for major adjustments. The perch-mounted adjustment is for fine-tuning. If I'm not mistaken, 2 open-ended wrenches for the engine mounted adjustment, 13mm and 14mm. Could be wrong, it's been a long winter.
Put your perch-mounted adjuster almost all the way out. Then do your major adjustment @ engine, now go back to your lever and fine tune it.
Good luck, holla if ya need anything.
Old Feb 6, 2008 | 01:01 PM
SNOWMAN's Avatar
thanks for the help ill check it out this evening.
Old Feb 6, 2008 | 03:26 PM
Bumble Bee's Avatar
You want about 1/4" free play in the lever. My clutch grabs almost all the way out on my F4 and the shop said it's gettng close to replacement time, but it don't slip so i'm good.
idrivea3
May 9, 2010 12:03 AM
02f4irider
Mar 6, 2009 07:50 PM
lakaiguy
Nov 8, 2008 10:54 AM
civiksi
May 1, 2007 05:54 PM
Stray Cat
May 1, 2007 02:21 PM
